crhiel's avatar
crhiel
Keystone Outback 240Urs/230Rs
Considering one of these rv’s. Checking if anyone is familiar with either one and if so, do you know if a full dress HD would fit...
  • I'm considering the same except for that my DR650 weights less than 400lbs. Too bad it doesn't have a side slide out.
  • jdc1's avatar
    jdc1
    Lwiddis wrote:
    Will 2200 pounds (230) and 2400 pounds (240) pounds of cargo capacity minus the weight of water, propane, batteries, pots/pans etc. be enough for you?
    That bike will weigh in at 1,200 pounds. That leaves you with less than 800 pounds of gear/food/clothing weight (considering propane, water, ect.)
  • Will 2200 pounds (230) and 2400 pounds (240) pounds of cargo capacity minus the weight of water, propane, batteries, pots/pans etc. be enough for you?
