Nov-03-2020 08:06 PM
Nov-12-2020 09:45 AM
Nov-12-2020 09:28 AM
time2roll wrote:
I would replace all springs and any worn hardware. Once I start tearing something down I want it right. Nothing worse than going back in because something seemed good enough to skip. I would have about 3000# springs (6000/pair) installed. When the work is complete get the trailer level.
Nov-11-2020 12:23 PM
Nov-11-2020 12:17 PM
Nov-10-2020 08:47 AM
GDS-3950BH wrote:Tyler0215 wrote:
Why would you even consider a "Shady" repair shop?
Perhaps because its a lot cooler than a sunny repair shop?
Nov-10-2020 12:05 AM
Nov-09-2020 07:07 PM
Nov-09-2020 06:17 PM
rockwind1 wrote:time2roll wrote:
If the springs are flat I would go up about 1,000 pounds rated (pair).
If you must just get the two I doubt it is a big deal.
Are you sure it is not the flipped shackle that makes them look flat? If you can just get the weight off the springs and everything positioned right again maybe it is fine.
Can you post some pictures?
Well. I flipped The shackle back so it was correctly oriented and the spring went from having a negative curve to having more of a flat shape. The other thing that I’ve noticed over the years I never thought it was that big of a deal but maybe it is, my trailer has always been sort of angled nose down so to speak when I’m driving along in my truck, I think my truck leaf springs have slowly lost some of their capacity. I think I’m gonna get some airbags finally. But I wonder if not having the trailer perfectly level while towing has just put more weight on that front axle. It’s definitely not an extreme amount of unlevel Ness, but it is noticeable.
As far as going up 1000 pounds, I really don’t know what the leaf springs are rated out right now, I was looking at the new leaf springs and they all have white ratings but I guess I’ll have to figure out what mine are first, I thought if you just went from a four to a five or a five to a six, it would just obviously be stronger. The guys at the Sort of RV shop recommended the six leaf springs instead of my four
Nov-09-2020 02:22 AM
Nov-05-2020 07:06 PM
time2roll wrote:
It is not just the number of leafs but the thickness and the metallurgy. Best to find the actual rating. Worth a call to the manufacturer. Usually the axle will have a tag with the rating or the model number to look it up. I would get springs that cover the full axle rating and maybe a little more. I would have to know the rating not just accept what they happen to have left over from the last job.
Example if they are 5200 axles I would be going 2750 on the springs (2750x2=5500)
Check the springs in the link I posted above.
6 leafs could be 2500 to 3800 rating
Nov-05-2020 05:44 PM
Nov-05-2020 05:23 PM
Nov-05-2020 02:46 PM
