jalichty wrote:
Our weight sticker showed a delivered weight of 7,200+ pounds giving us a total weight of around 2,700 pounds. We have never even come close to that total weight and don't tow with a full fresh water tank. Looking at the Jayco site the other day, it appeared to me that most of the HT line had a CCC of 1,750 to over 2,000 pounds.
Specs from Jayco 28.5RSTS I was referring to below, factory stated CCC is 1530 lbs.
As I said, a 2017 of this model on a dealer lot had a yellow sticker showing a CCC of a bare 735 lbs:
28.5RSTS | 2018 EAGLE HT FIFTH WHEEL
Weights & Measures
WEIGHTS
Unloaded Vehicle Weight (lbs) View Definition 8600
Dry Hitch Weight (lbs) View Definition 1490
Gross Vehicle Weight Rating (lbs) View Definition 10130
Cargo Carrying Capacity (lbs) View Definition 1530
MEASUREMENTS
Exterior Travel Length (Pin box to bumper) 31' 11"
Total Exterior Length 33'
Exterior Width 96"
Exterior Height with A/C 143"
Interior Height 95"
Interior Height (Bedroom) 74 1/2"
Wheel Base 236 1/8"
TANK CAPACITIES
Fresh Water Capacity (gals) 43
Water Heater 6
Gray Waste Water Capacity (gals) 32.5
Gray Waste Water Capacity - 2nd Tank (gals) 32.5
Black Waste Water Capacity (gals) 32.5
OTHER
Sleeping Capacity 4-6
