Looking for opinions and advice, please
vr200275
I have been trying to have an issue with my fifth wheel fixed for about six months now.
I have what I feel is excessive pin box flex.
I have been turned down for warrantee twice by the manufacturer of the fifth wheel and by the frame manufacturer.
It is flexing enough that a seam on the outside is separating and panels in the closet are coming off. Also closet doors are moving when transferring weight from pin to the landing gear.
I have taken some pictures and taken some measurements.
I also have some video but don't know how to post them.
Thanks
19 REPLIES 19
MarkTwain
vr200275 wrote:
I sent an email to Primetime Friday regarding the frame flex issue. They have not replied yet. Does anyone know a contact number for Forest River?
Turn the damage into your insurance as a claim. The insurance co. will get hold of Rorest River:)
Allworth
One bit of advice would be to make the subject line a little more informative when you start a thread.
Just saying.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
vr200275
http://www.forestriverforums.com/forums/f210/frame-flex-issue-2015-spartan-1239-a-109052.html
vr200275
Dayle1 wrote:
This document may be helpful. Unfortunately, it lacks any numbers for acceptable vs unacceptable. Lippert doc for flex
Thank you. I just posted on the Primetime forum. Was able to upload some videos there also.
Dayle1
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
Dayle1
I had a similar flex issue in 2011, not nearly as severe as yours. Thru a brand specific forum I found another owner with the same issue. I took lots of measurements and photos. I had no visual damage except the closet floor moving ( since it is directly attached to the frame). I went directly to the manufacturer and they brought Lippert in. My dealer provided the service bay and removal/reinstallation of the front cap. A Lippert tech added reinforcement at several spots.
I know at least 4 units received this repair and the frame design was changed within 6 weeks of identifying the problem. That is how it should work. Post your issue on a Primetime forum and seek other owners. If they have similar problems, then there is a design issue and you will have more leverage. If they don't, then there is a specific defect with your unit that needs to be isolated. Talk directly to Primetime, don't just work thru the dealer. If Primetime won't talk with you, then get a lawyer to send them a letter and post everything on an appropriate forum. Be the squeeky wheel.
Larry Day
Rig Photos
vr200275
vr200275
vr200275
My luck keeps getting better.
buc1980
A lot of new RV manufactures have problem.To bad good old brands went out of business that why I keep mine.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
chrizg
Frame flex on a 2015? Holy sheet. I would start with the manufacture contact. Be nice and send pics of hooked and unhooked. If they agree to fix it, be prepared to get it back to the factory.
SERVICE
Rick Koelndorfer
Service Representative
574-862-3053
RKoelndorfer@forestriverinc.com
23 Rockwood 2608BS
22 Dodge 3500 Crew SRW
Old
16 365 Landmark Charleston
06 Dodge 3500 Mega Cab 4X2 DRW B&W
16 Dodge 3500 Crew Limited DRW B&W Aisin 4.10
vr200275
2015 Primetime Spartan 1239
chrizg
I had the same thing on my 2009 unit. Things flexing when hooked to truck. I had to take it to the factory and they fixed it there. What make/model ?
23 Rockwood 2608BS
Old
12th_Man_Fan
I see you are a Good Sam member. You also need to send it to Action Line. Maybe if you stir up enough dust they will change their mind.
Your contract is probably like mine that you have to go to an arbitrator instead of being able to sue them and I would not hesitate to go to arbitration but I would have a expert look at the problem first.
Good luck.
Doug
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
