- HuntindogExplorer
Lwiddis wrote:
I have the brochure. It doesn't even mention the 1/2 bath as an option. The option appears in the build it feature on the website. Obviously a 1/2 bath in the garage cannot use the same tank as the main bath. That is why I had the question, which I now have the answer to. Two 53 gallon black tanks.
See https://www.granddesignrv.com/showroom/2020/toy-hauler/momentum/floorplans/398m
Fresh Water Capacity4
157 Gal
Grey Water Capacity
104 Gal
Waste Water Capacity
52 Gal - HuntindogExplorerMy present TT has two 42 gallon black tanks. This is an awesome setup for a TT. My goal was to equal that or better when moving to a TH. Grand Design seems to lead the pack in this area.
- JAC1982ExplorerOh man I would love black tanks that large. We were annoyed that the model year after our Impact doubled the tank size. We could boondock for over 2 weeks if we had ones that big. We never come close to filling the gray or running out of water.
- naytherExplorer
Huntindog wrote:
I finally got the answer.
It has two 53 gallon Black tanks. The black tank for the 1/2 bath in the garage also serves as the grey tank for that bath.
Not a big issue as it is the same as our present TT. We just do not use that sink.
This was a major item on our check list. And it just moved the 398 to the top of our short list.
That's a **** ton of Black capacity! You know the DW will relegate YOUR business to the 1/2 bath so you'll be golden. - HuntindogExplorerI finally got the answer.
This was a major item on our check list. And it just moved the 398 to the top of our short list. - HuntindogExplorer
Y-Guy wrote:
Pretty much what I found as well. I had previously crosssed the 398 off of my list because of the low 78 Black capacity, which was two 34 gallon tanks. It does appear that GD has upgraded the "M" class lately in some areas. Larger tanks being one of them. If the 1/2 bath, is now 52 gallon as well, it just shot to the top of my list.
From what I found a ew non half bath had 52 gallon black and 104 grety, a 2017 used w/half bath had 78 gallons black and 78 grey.
Hope that helps. - LwiddisExplorer IISee https://www.granddesignrv.com/showroom/2020/toy-hauler/momentum/floorplans/398m
157 Gal
Grey Water Capacity
104 Gal
52 Gal - Y-GuyModeratorFrom what I found a ew non half bath had 52 gallon black and 104 grety, a 2017 used w/half bath had 78 gallons black and 78 grey.
Hope that helps.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
