dawg37179's avatar
dawg37179
need a little help
This picture is of one of the storage doors at the front of my fiver. What do I need to use to re-attach/seal this? Thanks!
">pic here
  • Thanks! 7 of 10 screws were gone! Put in new screws and added some dicor and everything looks good!
    Thanks again!
  • This picture is of one of the storage doors at the front of my fiver. What do I need to use to re-attach/seal this? Thanks!
    Had this same happen on my Big Horn 5th. wheel. The shop just pushed it all back in and added more screws directly in the center of the seal around the whole seal. Fixed the problem:)
  • Probably going to need so e more screws to start with. I suspect the original ones haveulled out of the frame, either due to wood rot or holes being drilled too large in the first place. You will also need a roll of butyl putty tape and a tube of Dicor.
