Draw Tite 50066 and Reese RP50066 frame brackets seem to look the same in the pictures. I have a 2017 Chevy 2500 diesel crew cab, 6.5' box, a Pull Rite 2700 hitch, a set of 43" universal rails and now I need the frame brackets to mount the rails, Draw Tite are cheaper than Reese but they both appear identical in pictures. The Pull Rite hitch is rated at 16,000 lbs. My Cougar trailer is rated 9,000 dry. Which brackets should I buy? thanks!
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM TECHNICAL SUPPORT
