Blackdiamond
Oct 10, 2013Explorer
Yes soak the fiber plates in oil, look at the condition of the metal plates and check for warping, if they look good it wouldn't hurt to put some sand paper on a flat surface and run the plates over the sand paper a few times on each side to remove any glaze they might have. also look at the clutch basket, make sure there are no grooves worn into the sides, that can make the fiber plates kind of hold up or not engage all the way/smoothly, if grooved you could try sanding but it would be beset to get a new one, aftermarket.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
