Herzog
Jan 12, 2017Explorer
New 5th Wheel & New Truck - Running nose high - UGH!!
We recently purchased a 2016 Hideout 5th wheel (30 feet and 8000 pounds). Last summer I bought a 2016 Ram 2500 4x4 gas truck. We love both but when I hitched up to bring the RV home, it was running about 4-5 inches nose high.
I can't flip the axles as they came from the factory under the springs, and I have the pin box as high as it will go. There is about 6-7 inches of distance between the top of the bed rails and the bottom of the RV....seems good to go there.
The only recommendations I got from the dealer to raise the trailer were:
1. Build a box frame and put it between the trailer and the axles
2. Let it go and all should be ok.
I guess I should have received better advice for a $30,000+ investment...ugh
I don't want to add a box frame as it doesn;t sound very safe and the RV sits high enough as it is.
So, if I just "let it ride high", I assume I have more wear on the rear tires than on the front, but will it cause any other problems??
We only towed it about 40 miles to get it home but it seemed solid without any sway, but there was some chucking.
Any advice would sure be appreciated....I really think it is unreasonable that the newer trucks stand so darn high to begin with!
