tinner12002
Feb 05, 2017Explorer
jimmyfred wrote:
..........WHY , can't you simply purchase some of those blocks\inserts they use on the rear axles of 3/4 , 1 ton trucks and get longer Ubolts and add them to the suspension ? , jf
That's what I've done on both my 5vers. Installed 2" blocks under the springs raising the 5vers up just as we used to do, and still do on our trucks when putting a lift kit in. I do recommend that if you do that you also upgrade to heavier/thicker U-bolts. I think I had under $150 in my setup for a tandem axle hauler.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
