theoldwizard1 wrote:
SidecarFlip wrote:
If your converter is charging correctly, you should not have to check the water constantly. I check mine in my flooded cell deep cycle Group 31's every 3 months and I have yet to have to add water though I probably will this spring in as much as the unit is shore powered and in inside storage right now.
Batteries consume water (gas off) only when overcharged or are rapidly discharged. A good converter and reasonable discharge rates and a conventional battery will 'consume' little water.
I have often wondered about this ! I always suspected the "standard" converters (WFCO) were overcharging.
Actually, they undercharge not overcharge and WFCO's are noted for that. I kept mine but installed a Progressive Dynamics front end (it's plug and play) you pull the WFCO guts and replace them with PD guts and you pick up the PD 'Charge Wizard' as well. Mione would struggle to go into bulk mode (14.4 volts all the time) so I replaced / upgraded ir). Best converter sells the upgrade kit and it's worth it in my opinion.
I did it because I want the batteries to 'top off' in a reasonable amount of time when camping off grid and recharging with my generator and the stock WFCO would never top off the batteries, even on genny for 4 hours. Thats important to me because I run 2 CPAP machines mightly and I need full house batteries to do that.
Best I could get (in a reasonable time) was 80% according to my SeeLevel battery gauge. Not acceptable in my case. A few days off grid and I was flirting with 50% charge in the morning. No good.
