Njmurvin's avatar
Njmurvin
New queen foam mattress questions
My pre-owned AF came with a queen mattress which is some kind of Sleep Number knockoff that leaks air. So, I'm looking to replace with a memory foam mattress from Amazon. The platform is made for a full queen. I've read that some of these foam mattresses are too heavy for the struts that lift the bed. First question: Is 58-65 lbs too much for the struts? And second: Is a 10" mattress too thick for an RV? They offer the mattress in both 8 and 10 inch thicknesses (hence the range in weight).
  • I've found that you can change the mounting location of the gas stuts to change the mechanical advantage, thus the lifting and holding power of the struts for the bed platform. Cheaper than buying increased capacity struts. Worked for us on our first Excel fifth wheel. rockin'
  • Our 2014 AF mattress give the DW and I a better nights rest/sleep than our residence mattress. That broom handle idea sounds like a good quick fix. Enjoy the outdoors and your AF.
  • Old Duck wrote:
    ... Second thought, at hatchlift.com, they have a strut specifically for taking care of your problem. I've used some of their products for baggage doors and been happy with the results. They are great people to work with.
    Thanks. If needed, I'll check it out. Or, get an old broom handle to hold it up.
  • Headroom shouldn't be an issue ... full height bedroom and plenty of room between mattress and overhead cabinet. I was mostly concerned with the weight plus it would make the nightstands seem shorter. I suppose I could always upgrade the struts if needed. We use the storage under the bed.
  • A couple of thoughts, but first, on our AF (same model), we added a 1" foam topper. Without the topper it would stay up, with the topper many times I have to rest it on my shoulder or have my wife hold it up if getting a few things out. I have yet to change out the factory struts.
    First thought, I've seen a few who have added a second set of struts that have worked well to keep it in the up position.
  • My FW came with the upgrade memory foam mattress. I think it is an 8", but not too heavy for the struts. It seemed a little firm to me, so added a 2" gel infused memory foam topper. I'm not sure if all struts are equal, but mine still hold both up, and the comfort is great now too.
    Jerry
  • rhagfo's avatar
    rhagfo
    The struts will likely not support open, but help open.
    Height depends on your choice, will current sheets fit? Will it reduce the headroom too much? Only you will know this for yourself.
