Aka_the_breeze's avatar
Oct 20, 2013
New to me 5th wheel
Hello All , been lurking here for some time and now I have all my pieces in place! Got my new to me 2005 F350 dually and my 2008 KZ Montego Bay trailer... First issue just happened today , I unhooked and realized that the pins were not all the way in the landing gear holes so I hooked back up and secured them. At that time I went to lower the legs and nothing!! The motor winds but nothing moves??? I went through all my paperwork 3 times but cannot find any paperwork on who the maker is, or a diagram.... Any help will be great !
  • I don't know, but you may have simply exceeded the travel distance of the landing gear. Try retracting the legs and then move the pins to a different hole.
  • Tried that... Place marks on the tubes as my limits before using so I know that did not happen..
  • Just going off your information it sounds like a sheer pin sacrificed itself. Find the motor and follow along till you find where the culprit is.
  • Thanks to all who answered so far , to clarify-- I did in fact manually un hitch the fiver... Just looking to fix the issue now. I did try and trace all moving parts to find the weak link but there are none... Just the inside of the motor spins and nothing else.... After doing some searches here last night , I'm thinking maybe a worm gear ? Just cannot figure out the mfg???? The tags on the motor do not state the maker , just china.....
  • X2 on the shear pin(s). Remove the head of the jack on the motor side. The shear pin is on the motor shaft inside.
  • Update******
    We are all fixed , it was in fact a shear pin that broke.. I pin and some of my time and all done. Thanks for the in put to all!
