- HammerboyExplorer
cummins2014 wrote:
Ron3rd wrote:
Gonna go with the Superglide auto slider
I hope you did your homework on the Superglide, and the limitations on hitching ,unhitching . Had a friend grow tired of it after couple years ,and got rid of it ,that and the weight to deal with. Hopefully you are aware of all this, they are not cheap .
I had the Superglide on a previous truck and fifth about 15 years or so ago and had it for about 4-5 years before I parted ways with it. Quality built hitch but I grew tired of the limitations of hitching and unhitching as well. I think it was like 7 degrees or so in either direction or you would have to disconnect the head from the rest of the hitch and the same for hooking back up if you cannot get a relatively straight shot. Not to mention I was always cleaning and lubing the slide tubes.
My current rig I have a 18K BW Patriot non slider with my shortbed which I like much much better. This past spring I idled my slider base and purchased a fixed base off Marketplace as I never used the slider function in any sort of turn. The only downside of course is the potential to kiss the cab but in the 5 years with our current rig I cant say I've ever been close, just have to be aware. The 18K Patriot I have now is also much lighter which means I can easily remove it by myself in (head pops off by simply grabbing the handles) without help or the aid of a winch. When I had my slider I used a cheap Harbor Freight electric winch to lift it out.
Cannot say enough good about B&W, well designed and build quality, built here in America and a great company that stands behind their products.
Dan - cummins2014Explorer
Ron3rd wrote:
Bayley wrote:
Ram short bed and an Andersen ultimate hitch over a B&W turn over ball and your worries are over. I have jacked pretty hard at times and never come close to the cab.
Just ordered the Andersen. Went with the standard rail kit though.
Great choice . - Ron3rdExplorer III
Just ordered the Andersen. Went with the standard rail kit though. - BayleyExplorerRam short bed and an Andersen ultimate hitch over a B&W turn over ball and your worries are over. I have jacked pretty hard at times and never come close to the cab.
- Ron3rdExplorer IIII do have interest in the Anderson too
You won't regret it.
I saw a New Dodge with a new 5th wheel. The new Dodge had a nice new dent in the back corner of the cab.- Ron3rdExplorer III
I've used the hitch before with no problems. Two friends have the hitch with no problems. I'm familiar with the Superglide - Ranger431ExplorerI’ve got a short bed F350 and a 2020 Jayco Eagle I have a manual slider, and am very glad I do. I don’t need to use it all the time, but there are a few tight spots I’ve been in that I was very glad I had it. The manual is a little bit of a pain, but much less of an inconvenience than replacing a back window.
- MFLNomad II
Curly2001 wrote:
Just one more note, make sure of your bed/hitch height before you go with a slider. My trailer really doesn't need the slider but I thought I had to have one. The slider will add to your hitch height and it could make your trailer nose high. I had that issue with mine. Got rid of the slider and so far we are good.
Curly
Ha, famous last words. Just kidding, glad a non-slider works for you! Having a GM is a big help, due to the longer than other brands distance, from axle center, to rear of cab.
I've towed with several 6.75 bed Fords, and a couple different FWs, while never having a slider hitch. No problem so far, and been working fine since 99.
Jerry - Curly2001Explorer IIJust one more note, make sure of your bed/hitch height before you go with a slider. My trailer really doesn't need the slider but I thought I had to have one. The slider will add to your hitch height and it could make your trailer nose high. I had that issue with mine. Got rid of the slider and so far we are good.
Curly
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
