hmar1
May 11, 2014Explorer
Noise when walking across floor (ductwork) FYI
If you have noise when walking across floor from ductwork, here is an easy fix, access your ductwork from your basement, attach double sided tape to the duct, then attach foil covered bubble wrap insulation to the tape, then run duct tape across the width of duct up the sides, problem solved.
