Maintcpo's avatar
Maintcpo
Norcold 611 vlt not working on electric
Have a new to me 2015 Heartland sundance 245
rl with refer that works great on gas but no electric. Power at plug and thru cord to board, heating element ohms as good is a bad power board or do I look somewhere else?
  • There should be a fuse on the board. Have you checked it?
    Bad relay on circuit board
  • Check for 120 volt output from the circuit board.
    What is ID number on the circuit board?
  • Maintcpo wrote:
    2 fuses on the board both good
    F3 fuse is for the 120V AC
    F1 fuse is for the 12V DC
    Did you TEST fuse or just visual inspect?
    Did you TEST fuse clips?
    Any 'error' codes....?
    ON LED ON and GAS LED Flashing?
    L1 is 120V AC HOT lead
    L2 is 120V AC Neutral
    AC HT HI 1 is 120V AC HOT to element
    AC HT LO 1 is 120V AC Neutral from element
    120V AC between L1 & L2
    120V AC thru fuse/clips
    120V AC between HI 1 & LO 1 ----provided fridge is calling for 'heat cycle' (Thermostat calls for cooling...K2 Relay on circuit board Closes)
    NO 120V AC to element...bad circuit board
