cdlaine
Jan 02, 2016Explorer
opportunity to use manual (crank) on front jacks....
So, question for the wise forum members....
This a.m. leaving the desert camp site, went to raise my front 5ver
jacks to allow hook up to the hitch. Only the "retract" toggle worked, the "extend" toggle (when activated) was anemic at best.... frustrated, I checked the fuse (intact), was still hooked up to shore power...could not figure out what the problem indicated. So, decided to use the manual bar crank.... if you have not done this I suggest you try it at least once. Better eat your Wheaties. The engaging of the rod end with the mechanism is problematic as visualization is limited. After numerous attempts correct contact was achieved and the heavy lifting was initiated. All went well from that point.
As I was making my last checks prior to departure I looked inside my water/flush/winterize compartment and noticed that the day before I had turned the "battery disconnect" to "on" . After returning to "off" both front jacks functioned correctly.
I am not sure I am explaining correctly ...but the moral to the story, don't be like me. Make sure your manual assist mechanism is functioning correctly, and, I guess, leave the battery disconnect alone when out camping. Ha !
So, question... why does the battery disconnect switch position impact the powered front jacks when connected to shore power ? or,
was this just a coincidence and I need to investigate further ? :h
Charles
Charles
