RetiredAFinND's avatar
Jun 06, 2013
Parking fifth wheel on a grade
We are heading out to visit some family in California soon and taking our 28 foot Sunnybrook fifth wheel. The only concern I have is where I have to park the fifth wheel is in the driveway which to my recollection is fairly steep. I was wondering if anyone can give me some idea of how to figure out how steep of an angle I can safely park and level my fifth wheel and any suggestions on any extra safety measures I should be taking to make sure it is stable. My thoughts were if I measure from the back bumper to the front jacks (23') and then have them run a level string line down the driveway that far and tell me what the distance is from the level string to the driveway I might be able to figure out if it is even possible. Any ideas or information would be greatly appreciated!
  • I've used fairly large wood blocks under my landing gear. My landing gear pads had 1/2"? holes in them. All my blocks had holes drilled in them as well, and I had bolts that I would drop through the pads into the blocks so that the pads could not slip off the blocks. This idea may work for you in the situation you will be in.
  • Go to the nearest campground. Don't worry about parking on a bad spot.
  • If it is even just moderately steep, it is likely thet you will drag the rear bumper and or the rear stabilizer jacks trying to get in. Either forward or backing, although backing seems to be a worse condition.
    Have a spotter watch the rear overhang very carefully when you try to enter. It is easy to rip a jack off (don't ask).
  • If drive is VERY steep, its doubtful you will be able to level it. If you are planning on unhooking, chock all wheels, release hitch, raise trailer only enough to see pin movement, STOP raising, let truck move forward very little. If trailer moves back toward hitch, STOP, Rehitch and park elsewhere.
    Jim
  • I generally turn to this site for all my chocking needs. They are also quick on answers if you need to email them for any info.
    http://www.chocks.com/grandlist.php?Type=1&Mat=2
    Someone posted that opening a slide in an uneven trailer is bad? I thought i specifially read here that was fine to do?
    My driveway is sloped. It's a trust issue for me. Our first TT I was nervous about early on, then grew to trust it. Now that we've upgraded this year, heavier, and longer tt, i'm gradually working my way back to trusting my equipment. etc...
    I'll be leveling mine tonight to get the fridge running for the weekend.
    My front tires sit about 2" lower than my rear tires in my driveway (sloping garage to street). I prop up my front tires onto 2x6's to compensate, then just raise the front up to the desired height.
  • I once parked our 38ft 5th wheel on a hardpacked dirt driveway that was so steep the front landing gear were as low as they could go to get near level. The rear of the 5th wheel stuck up in the air about 4 feet. I used my X-chocks plus a couple of split logs behind the rear tires. My wife was very leary when standing at the rear kitchen counter...all she saw was a big drop off out the window.
  • Tire chocks (if dropping the trailer) are a must, I hate putting more then a 2x6 under the landing gear - if it slips off the damage is huge..
    As far as the string line, measure from the axles to the jacks, the bumper (unless it hits the ground) doesn't matter.
  • Parking on a steap drive way is not a big deal. But you should not run the refer or attempt to open the slides under anything but level conditions. That means trailer level, not necessairly the parking spot.
