MTPockets1's avatar
MTPockets1
Pin weight
How many know their actual pin weight. Serious 5vr's should. Most discussion regarding trucks are more about towing capacity, when it needs to be about pin weight which is the biggest part of cargo capacity. Many seem to use a percentage of GVWR and go with that number to make it fit their truck cargo capacity. I know my pin weight is 3300 lbs which is close to 23% of my GVWR. If I used a more common approach, I would be well under 3000 lbs. I've seen some use numbers as low as 15% to say their pin weight is 2000 lbs. or less. There is no way to know your pin weight unless you visit the scales and do the math. Do you know your pin weight?
