Sort By
- Coach-manExplorerBut if CSA did their job there would be an actual device that you plug into the four wire 240 volt 50 amp plug that would provide you with the 30 amp protection that everyone is trying to make you beleive is a matter of life or death! And how can you protect that device, which is rated at 30 amps from a possible problem between it and the 50 amp circuit breaker, (as pointed out that is "upstream" and you are not protected! Therefore there is nothing that will protect you, therefore the dog bone adaptors are inheartly dangerous and should not be sold or used anywhere!!!
- bfast54Explorer
spud1957 wrote:
We do what everyone else does. We read it and say "isn't that interesting", rip the tag off the adapter and plug it in anyway.
CSA did their job and advised us of the risk involved in using the adapter. It's up to the consumer to adhere to it.
How many people screw a 100W bulb in a socket that says 60W maximum.
S
Actually...soon no one will be able to do that---- because the light bulb POLICE are going to outlaw (100 )----- hundred watt incandescent light bulbs
so that point will be moot......:p - spud1957ExplorerWe do what everyone else does. We read it and say "isn't that interesting", rip the tag off the adapter and plug it in anyway.
S - Coach-manExplorer
spud1957 wrote:
Here is a link to the Go-Rving catalog.
My thought is that they are not CSA certified i.e. stating the requirement for a 30A breaker. The ones at the local walmart do have the CSA certification.
The page is for the Camco adapters which specifically states "not for sale in Canada".
Go-rving electrical adapters
Perhaps Mr Coach-man has a story for this as well?
Well not being from Canada and have never used an RV park in Canada I do not know what you do when using that adaptor. Please enlighten me, as in the USA I have never seen at an RV park a 240 volt 4 wire plug rated at 30 amps!
My point is, unless you have defective wiring or cord you can not draw more than the 30 amps your rig was designed for! You are therefore protected by the 30 amp main circuit breaker in your RV! If you have defective wiring or cord you will have a problem regardless of which recepticle, 30 or 50 amp recepticle you used. The statement that dog bone daptors are dangerous is ridiculous, which is what started this usless discussion! - spud1957ExplorerHere is a link to the Go-Rving catalog.
Perhaps Mr Coach-man has a story for this as well? - Me_AgainExplorer III
joebedford wrote:
Coach-man wrote:
No, only those of you who use 30/50 dog bones; not us who use 50/30 dog bones.
So dog bone adaptors are ileagal devices and anyone owning them should be fined or jailed for creating an electracle hazard
I really do understand the point the people are making about undersized cables being a risk / fire hazard. However, I think the biggest risk is the poor state of repair of many 30A receptacles at campgrounds. On the whole, I think you're less at risk using the 50A receptacle if only because it probably hasn't been worn out through use.
All things equal, that is a good 30A outlet and a good 50A outlet, there is no difference in the power you will receive in a 30A trailer from the 30A outlet vs the 50A. I bought an adapter just for those cases where the 30A outlet shows to be damaged or burnt. The correct steps would be to plug in if you have to with the adapter and then ask the park to move you or replace the bad outlet. Any park that is being well run will fix such issues on their own or when it is pointed out to them.
Chris - joebedfordNomad II
I really do understand the point the people are making about undersized cables being a risk / fire hazard. However, I think the biggest risk is the poor state of repair of many 30A receptacles at campgrounds. On the whole, I think you're less at risk using the 50A receptacle if only because it probably hasn't been worn out through use. - Me_AgainExplorer III
Coach-man wrote:
So dog bone adaptors are ileagal devices and anyone owning them should be fined or jailed for creating an electracle hazard? Site anyone ever anywhere that has been arrested and charged with this crime! Of course you have failed to acknowledge that an anti proton from outer space could also strike the ground terminal and blow up all electrical devices in a two mile radius! The fact is they adaptors and their use is leagal and safe anywhere and the "things" you are citing could cause a problem weather plugged directly into a 30 amp plug or an adaptor!
The original post on this issue was to inform people of the risk! As someone pointed out that the one sold to him in Canada has a warning about the need of a 30amp breaker feeding it. I will check mine when I go to the trailer again. Those sold in the US may be labeled with the same warning.
If you choose to ignore such warnings that is fine, just don't shoot the messenger because you want to ignore the warning.
Being informed is better than not being informed.
Chris - Coach-manExplorerSo dog bone adaptors are ileagal devices and anyone owning them should be fined or jailed for creating an electracle hazard? Site anyone ever anywhere that has been arrested and charged with this crime! Of course you have failed to acknowledge that an anti proton from outer space could also strike the ground terminal and blow up all electrical devices in a two mile radius! The fact is they adaptors and their use is leagal and safe anywhere and the "things" you are citing could cause a problem weather plugged directly into a 30 amp plug or an adaptor!
Water-Bug wrote:
Me Again wrote:
What he ^^^ said.
However. Put one meter lead in the 3 o'clock hole and the other in 9 o'clock and you will read 240V, there are two hot legs and are opposite phases.
Chris
Actually they ARE the same phase, just opposite ends of a transformer that has a center tap neutral. AC power in the US is delivered in three phases that are 120 degrees offset from each other. That is because the generators are built with three windings.
http://www.programmablepower.com/support/FAQs/DF_AC_Distribution.pdf
About Fifth Wheel Group
19,010 PostsLatest Activity: Apr 16, 2025
