Huntdog's avatar
Huntdog
possible freeze problem in water system
Greetings,
I have an 27' 05
Fleetwood 5th wheel, that I just bought and was not familiar with all the drains, so I think I have a freeze problem. I have put some water (10-15gals) into it, turn on the pump, and all I get out of the faucet is spurting. About a month ago I looked around and saw some water in one of the outside storage compartments, and the way it is leveled, it may have come from the hot water heater. I was there this past weekend and had the pump on, and could not find any leaks at all, and still getting the spurting from the faucet. And the pump does not go off, just keeps running. It seems that air is getting into the lines, but not leaking anywhere. Is it possible that the air leak is above the water-level, and I need to fill it up with water to find the leak?
Thanks,
Jim
