powermax upgrade
bbaker2001
I am wondering if any real difference between the Inteli-Power 4600 upgrade and the PowerMax PM4B-45 (45 Amp 4-Stage Converter/Charger)
1 is upgrade. and 1 is deck mount
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
5 REPLIES 5
time2roll
If you want fast charging from a generator get the PD.
For just plugging into the pedestal they are about the same and both very good.
Latest thread on poor PowerMax charging on generator.
MdMike1007
I just put a 60amp Powermax Boondocker in my Heartland Elkridge 5th wheel to replace the WFCO stock unit which failed. PM4B-60. Great unit. Randy was a big help! It replaced my 55 amp stock unit.
bbaker2001
called Randy, he says go with upgrade.
case closed
BB from California
2015 Ram 3500
2001 Cardinal
SkiSmuggs
You could call BestConverter.com and see what he says about it.
2015 F350 XLT PSD 6.7 Crew Cab, Andersen Ultimate hitch
2012 Cougar High Country 299RKS 5th wheel, Mor/Ryde pinbox, 300w of solar
pianotuna
Nomad III
Nomad III
The powermax is of newer design, so I'd lean that direction. Both are adequate.
Regards, Don
