โDec-03-2015 05:44 PM
โDec-04-2015 03:19 PM
โDec-04-2015 12:31 PM
โDec-04-2015 10:59 AM
Carl n Susan wrote:
Check out this similar topic here on RV.net concerning propane heaters:LPG Portable heaters
Also this link is referenced in the above posting, but in case you miss it there, it is interesting enough to link to here: RV Heater
โDec-04-2015 10:27 AM
โDec-04-2015 09:21 AM
โDec-04-2015 08:55 AM
โDec-04-2015 06:59 AM
bid_time wrote:rhagfo wrote:Just like your stove and oven does.
:h
you are looking at putting an additional Propane heater and connection INSIDE your 5th wheel??
This is a device that consumes oxygen inside the 5er and produces Carbon Dioxide.
โDec-04-2015 06:44 AM
:h
โDec-04-2015 06:15 AM
rhagfo wrote:
:h
This heater is safe for indoor use in small recreational
enclosures, having means for providing combustion air
and ventilation, such as enclosed porches, cabins, fishing
huts, trailers, tent trailers, tents, truck caps and vans.
It may be used for emergency indoor heating when
connected to a disposable 1 lb. propane cylinder and
for indoor use in commercial enclosures, having means
for providing combustion air and ventilation, such as
construction trailers or temporary work enclosures
Me I would just run the furnace.
โDec-03-2015 08:16 PM
โDec-03-2015 07:48 PM
My concern is leakage. I have seen my share of air fittings that leak, not sure if the propane ones are built better and safer?
โDec-03-2015 07:18 PM
โDec-03-2015 06:24 PM
โDec-03-2015 06:16 PM
