DHCamper
Dec 04, 2015Explorer
rhagfo wrote:
:h
you are looking at putting an additional Propane heater and connection INSIDE your 5th wheel??
This is a device that consumes oxygen inside the 5er and produces Carbon Dioxide.
This heater is safe for indoor use in small recreational
enclosures, having means for providing combustion air
and ventilation, such as enclosed porches, cabins, fishing
huts, trailers, tent trailers, tents, truck caps and vans.
It may be used for emergency indoor heating when
connected to a disposable 1 lb. propane cylinder and
for indoor use in commercial enclosures, having means
for providing combustion air and ventilation, such as
construction trailers or temporary work enclosures
Me I would just run the furnace.
Carbon Monoxide is the villain here. You are putting a lot of faith in the performance of the catalyst and the detector/switch. Some folks that use ventless gas logs in thier house report headaches, which makes me wonder about the level of quality built into these systems. Coupled with the chance of gas leaking: Definitely not for me.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
