- High5erExplorer
2oldman wrote:
High5er wrote:
Ok.. I trust you. But I don't know why I need to.
Fuel weight changes daily, trust me.
Thank you for your trust.:D Here is a straight-forward read on propane: http://www.propane101.com/propanevolumecorrection.htm
I'm not really trying to prove anybody wrong here. Just want people to understand weight is a factor when measuring fuels.:W - ACZLExplorerGet my tanks filled at local LP dealer that puts them on a scale. I take them out of the 5er and up to LP dealer to fill. New coach--tanks filled. Old coach not filled by dealer.
Never thought of how the trucks fill or know when full on tanks at homes. Good point.
FWIW, there is a number stamped into the collar of tank that has tare weight. If you have a scale at home, you can place tank on it to see how much it weighs above the tare weight number and that will tell you within reason how much you got left. OR just pour hot water alongside of tank to see where frost line/fuel level is. - 2oldmanExplorer II
Fuel weight changes daily, trust me. - Temperature does not affect mass... only volume.
My cylinders do seem to take on more volume when the bleed screw is used aggressively. - N-TroubleExplorerMine came filled when I bought my 5er couple years ago. How would you do a PDI if they were empty?
- FSJPatExplorerAt my old station in VA they did it by gallons. They had a scale (old and rusted), and when I asked the guy if he was going to weigh the bottles, he just laughed and said they haven't weighed bottles in years.
My new station in WA charges by liquid gallon also. - High5erExplorer
2oldman wrote:
High5er wrote:
The old school comment implied that dispensing by volume was old school. It's on page 1. I'm pretty sure meters came along way after scales.
Those old school sliding weight scales also work in all climates where moderns scales would freeze up in places like Minnesota. Just MHO :)
Of course I could have completely misunderstood his comment.
Fuel weight changes daily, trust me. I did this stuff for living. Maybe this will help: :) https://www.orangecoat.com/the-truth-about-filling-20-lb-bbq-grill-propane-tanks - 2oldmanExplorer II
Of course I could have completely misunderstood his comment. - High5erExplorer
2oldman wrote:
bpounds wrote:
I don't understand the old school comment either. The last time I got filled by weight the guy used a scale that looked like something from the 1800s.
. They use a meter that measures gallons. And the bleed valve tells them when liquid has reached the top. Old school? I still by gas by the gallon.
I believe that fuel changes weight depending on the temperature. Even aircraft are fueled by weight, (not gallons). Those old school sliding weight scales also work in all climates where moderns scales would freeze up in places like Minnesota. Just MHO :) - 2oldmanExplorer II
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
