Pullrite Superglide Hitch Problem?
Only_True_Mosno
So I invested in a brand new Pullrite Superglide hitch to go with my new Cougar 327RWS Fifth Wheel...installed at Camping World.
I am having a lot of trouble getting it to lock on when hooking up. U hooking is easy. Here is what I have tried thus far...
Made sure I am exactly straight when hitching up....
Lower the Fifth to ride up the hitch...
When I get it to finally lock it first makes a quiet thump which several folks have thought I was locked in...but I wasn't. It takes a second loud thump to fully lock in. Problem is half the time it won't lock in at all and I have to pull up and try again. Thoughts ?
2018 Montana 3721RL
2018 Ford F350 Diesel
Life Comes Down to a Simple Choice...Get Busy Living or Get Busy Dying...
19 REPLIES 19
BillB3857
When I got my PullRite slider, the dealer welded the adapter plate to my pin box. A dribble of weld was holding the hitch too high. A die grinder quickly fixed things.
2004 Silverado LB7 D/A CC LB DRW 4x4, Firestone RideRites, Air Lift Compressor, Line-X Bed Liner, Retrax Bed Cover, Backup Cam, Pullrite Super 5th Hitch, Rear View Cam
AstroStart 2205A Remote Start
2014 Keystone Outback 5th Wheel
Trail-Air Pin Box
milo
I've only hitched & unhitch twice so far (so what do I know). First time towed from dealer. The second time I hitched up (practice hookup) I backed within bout 3-4 inches of the pin and made the height adjustments (right at the base of the hitch plate so it tilts the hitch plate) and slide the hitch under the capture plate with just enough force to lock it. Worked like a charm. Gonna practice several more times before our first trip.
Janet & Milo ...47 fantastic yrs 2gether :B
Mona Yorkie & Buddy our beloved Beagle (both in spirit)
2013 F-150 Kodiak Brown XLT 4X4 HD Ecoboost
2014 Cougar 26sab
Living under the best Government money can buy ... Bob Brinker ๐Ÿ˜‰
JamesBr
Not running a SG hitch, but do have a pullright. If the trailer is not about 1/2" low when hooking it will not latch for me. This is with a properly lubed hitch and gear setup. Any lower and its too rough on the truck and trailer, any higher and it wont grab which is nice since it seems to avoid high hitching even on a standard 5th wheel hitch.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
nazpaz
Mine likes to be a little low, but not too much. There's a spot where it hits something resulting on a solid sounding thump. If I hear that I know I have to pull up and change the height of the 5ver, usually I move it down an inch or so and I'm fine. I have yet to understand what is happening to cause the thump - but once I hear it I know that I need to adjust the height a bit.
-G.R. "Scott" Cundiff
Our Here and There Blog
2005 Safari Cheetah 38PDQ
We've visited them all (but not always with the RV)
Vulcaneer
Alright...I may have overstated the hardness of the hit. But you cannot be too timid when backing in. Not hard enough to cause damage. But hard enough to get a good release of the jaw.
Another thought might be to remove the hitch plate and turn it upside down on a bench. Then lube up the pivot points well. Just be careful not to release the jaw by hand. It can catch ( and really hurt) fingers. But actuating the jaws after greasing well might loosen things up a bit for you.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
sk734
After I towed with mine when I had one it seem to loosen up just a little and hitched just fine after that. They are very tight when new.Good luck. My B&W Companion is the easiest hitch I have ever owned to hitch and unhitch if you should ever change.
Duck
I was told to always ride up the hitch. I aim for half way up the slope and never have had a problem.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
ol_Bombero-JC
tsetsaf wrote:
Vulcaneer wrote:
Make sure you are lined up exactly in line with the hitch. Make the inbox ride up on the hitch plate. BACK IN RATHER HARD AND SOMEWHAT FAST. DON'T BE TOO GENTLE. Be aggressive when backing in. It needs to hit hard.
The biggest Noobie mistake is being too timid when backing in.
I completely disagree. I take it easy and it works everytime. Trick is finding the right height between pin box and hitch. Some need to ride up others need to be just level. Once you know what yours is you will have it in the bag.
Another *emphatic* disagree! (along with "mileshuff')
No need to be aggressive!
Been doing this for years with SG.
(From "day one" - never had a 5th or a SG before)
You should either be exactly level - or (best) "ride up" the hitch a bit. Back in slowly until latch slams shut.
*VERY* audible latching sound!
Suggest you have a discussion with PullRite Tech line.
Maybe it's operator error -or- maybe something isn't right...:h
mileshuff
I never have to back in hard at all. No problems hitching. Backing in hard maybe hard on the 5'ers front lifts perhaps. If you have to slam it then something is wrong!
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
tsetsaf
2006 Ram 3500
2014 Open Range
"I don't trust my own advise!"
Vulcaneer
74vette
Mine will do this if I do not have the capture plate low enough to ride up on the hitch. I make sure the plate rides up on the hitch
ronday
X2 Let trailer ride up on hitch, been doing this for many years. It is possible to high hitch and unhitch. Ron Day
2008 Chevy 2500HD D/A, Crewcab SB, Pullrite superglide
2011 Big Country BC 3250TS 33ft 5ver
2005 Fleetwood 26ft 5ver
2005 Sun Lite Truck Camper
Ron - 29 yrs HS Tech Teacher (ret) 24 yrs USN/USNR Chief (ret)
Sheila - 29 yrs HS Home and Careers Teacher (ret)
wtmtnhiker
I used a Superglide for about 11 years without any problems. Contrary to others experiences I always had to make sure to have a fair amount of weight on the hitch as I backed underneath it. Never had an issue hooking up in all those years if I let the trailer ride up the hitch.
bgbassman(bluegrass bass man)
