RCMAN46 wrote:
I would recommend leaving the trailer hitched to the truck and raise the landing gear.
After jacking the frame near the axles use cribbing or jack stands before doing any work under trailer.
Well both times I have done work on both axles at the same time I didn't have the option of leaving the TV attached. I also didn't consider as the cribbing is very stable, even a 12" square stack. Once the tires were off the ground I shoved hard at the back of the 5er barely moved, not worried about falling.
One other thing the other thing you may notice in the second picture that surface below the trailer slopes slightly to the left. I corrected for this by shimming the first layer to level in both directions.
One word of caution NEVER use cinder (concrete) blocks to support anything you plan on putting your body under.
First was Driveway was only long enough for the trailer.
Second current, end unit of Town Houses, enough space for the 5er, but TV would block neighbors garage.
