rosewood1's avatar
rosewood1
raising ride height
i have a 2007 mobile suite which rides a little nose high. i have lowered the hitch and raised the pinbox all i can and i noticed onother set of holes in the spring mount which would certainly help this situation. does anyone know of someone who has done this? thanks.
  • rosewood1 wrote:
    my springs are under the axle. i am also trying to raise th rear of the trailer because we do mostly mission trips in our rig and sometimes the places we go tend o dag in the rear.
    Several companies make "axle flip" kits. The one piece of advice that I've seen more than anything with them is to weld the spring perches in place on the axle as some have reported the perches slipping. Wish I'd done that on my old Komfort. I'd have no issues with putting the spings into the lower holes on the hangers, if you need to. Also, if you're going to have things apart, make =sure= you check the spring bolts and bushings. Even if there's no real wear, you'd be best served to install a wet bolt kit that has heavier spring shackles, bronze bushings and greasable bolts.
    A quick check, and an axle flip kit is < $90 most places and wet bolt kit is < $125.
    Lyle
    Did that on a prior rig and worked fine for towing.
    One item to check for is the stabalizers. Just had the standard sizzor style which worked fine and felt very stable. Then after raising it, the trailer felt all wobbly when inside, so you may need to upgrade to strongarms or something similar. Also, may need a stool to put under the steps.
  • Watch your height when you raise your rig. You might leave your AC's behind one day.
  • Congrats on the new rig!
    I raised my last TT that way and used it for years without issue. I'd do it again if needed.
  • my springs are under the axle. i am also trying to raise th rear of the trailer because we do mostly mission trips in our rig and sometimes the places we go tend o dag in the rear.
  • If I was going to do anything, I would get new, longer u- bolts and taller blocks that go between the axles and springs. This will raise your camper, but will also raise your center of gravity. Most of the 5th wheels that I see are running a little nose high. So depending on how much yours is off I’d leave it as is.
  • Describe a LITTLE nose high. My FW is in lowest hitch setting, and about an inch or so nose high, depending how I am loaded. While I also have an option of raising the trailer, by using lower spring holes, IMO, would not be worth the bother, and could weaken the hanger due to more length, and less support.
    Hole space is 2"s lower, but just on outside ends. It would likely lift the entire trailer an inch or so. A FW should tow just fine, with a slight nose high. Many tow too much nose high, and can add weight to rear trailer axle, and may cause bouncing/chucking.
    Jerry
  • You must be pulling with a 4 wheel drive vehicle? I've heard of flipping the springs of the trailer to the top side of the axle
