Re-level 5er with lippert hydraulics
Carls_wood_work
Our trailer needs to be re-leveled after sitting in our spot for 6 months. I have found a wealth of info on the system but nothing about re-leveling. Do the slides need to be in? Do I need to be in manual mode? Can I just push Auto Level? Need help
32 REPLIES 32
dedmiston
Moderator
Moderator
Hi Carl - Welcome to the forum.
Interesting question for your first post..
I never deploy my slides until I'm level. Running them out when the fiver isn't level puts stress on them and can make them bind up.
But you're already kind of out of level and your slides are already out. You're probably better off running the auto-level as you are instead of running the slides back in. Hopefully you're not that far out of level.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
wvcampers
I have done a relevel a couple of times. I don't put the slides in. Just push the level button. Keep in mind that the trailer will not return to hitch height when you hit the hitch button. it will go to where it was before you did the last level. you will need to manually get the trailer to the correct height to with up.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
mooky_stinks
Put your slides in and hit auto level.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
