GPG52_
Dec 14, 2017Explorer II
This is a copy of a forum post we did in 2015:
"We just completed a holiday run from Toronto, Cnd to Kissimmee, Fl.
Some of stats from this trip.
TV: 2014 Ford F250 Super Duty, 6.3 gas, 4.30 ratio, 6 spd.
Coach: 2014 Cougar 327 RES, (Mfg. spec's 10,260 lbs., 1,625 lbs. pin)
Have yet to put it on a scale but could likely add 1,700 lbs. for gear and 1/4 tank of fresh water.
US 90, 79, 19, 77, 95, 4.
Return trip: 2,806.7 miles
Moving time: 56.28 hrs
Moving average 50 mph
I tried to hold the speed at 62 - 63 mph and tried to keep the RPM from going above 3,000. This meant slower hill speeds.
South bound April 2,3 & 4th, 2015
Used speed control when not on wet roads.
6.6 mpg (we had heavy rain)
172.141 US gallons, Average $pg $2.27,
North bound April 16,17 & 18th, 2015
Used manual gas pedal especially in mountains to keep the RPM in check.
6.9 mpg
172.338 US gallons, Average $pg $2.38
Tried to fuel at Flying J and Pilot's to take advantage of the Good Same discount and larger rig friendly fueling stations.
NOTE: we did get up to 9.047 mpg in the Southern state flat lands, but the Blue Ridge, Appalachian , Allegheny mountain ranges brought us down to 6-7 mpg area.
YEP... we did see those diesel dually's through Fancy Gap passing us, but for our use the cost/benefit still supports a single axle gaser.
Coach pulled extremely well... very much appreciated especially after some of those longer days behind the wheel. (single driver)
Nice trip, fuel consumption was at the lower end of our expectation but no big surprise.
Happy trails!!!!
GPG "
6.9 mpg
Happy trails!!!!
GPG "
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
