- EndrickenExplorerDoes REESE still recommend greasing the Coupler through the Grease Zerk before every hookup?
Does the Airbag still "puff" out the air through the 45 PSI (?) Pressure Relief - requiring VERY SLOW refilling after most several hour tows on any rough road?
Was way too much maintenance for me.
Also, within 9 months of installation a large TX pothole bent it and cracked my front frame member. Fortunately REESE refused to provide a replacement under warranty so I went back to the STAR PERFORMANCE ADAPTER. It includes a glider motion, has not broken my frame and only needs greasing every 2000 miles (6 Grease Zerks).
Hope it works out better for you! - LanceRKeysExplorerI have a bumper pull now, and will be going with a 5th wheel when the kids get a little bigger, it is exciting to see all the options out there. I don’t want rails mounted in my truck, so this may be another option. The extra shock absorbers look like they would help as well. Good video.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
