Reese Goosebox
oilslick
The Reese Goosebox?? I've searched the topic but it seems there aren't many out there using it yet, I would like to hear comments from current users as I'm thinking of giving up the B&W companion in favor of safety chains.
20 REPLIES 20
DavisK
All goosenecks require safety chains in VA. Only 5th wheels can be towed without them.
2013 Silverado 2500 HD LTZ CC 6.6L Duramax Diesel
2014 Sunset Trail SF270BH
Holly & Buster, rescued mini Dachshunds
45Ricochet
I've never heard someone giving up a B&W companion for any reason none, zip nada. Lets see here, a 5th wheel hitch is pretty simple to back into, straight shot first time every time. Now you bring a ball into the equation not to mention chains which 5er's don't need.
Sounds like your retired and have plenty of time my freind. Believe me my GN is never a back under 1st try ever ( can't see it) . Same with the boat although it has a wheel to cheat or move around at bit.
IMO your trailer emergency brake switch is much safer and eaiser than safety chains.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
DirtyOil
some locations it affects the ability to double tow as the primary connection cannot be a ball hitch).
Transportation Alberta:
Two trailers can only be towed if the lead is a fifth wheel trailer with at least two axles in tandem. (length of TV and first trailer to a max of 20m)
No rules on what one uses for a hitch for the fifth wheel trailer .
No specified rules on safety chain requirements for RV trailers in Alberta either. must correct this 0-2 chains, 0 if fifth wheel, 1 for other,, 2 is recommended but not required.
BC requires one safety chain for RV trailers.
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
DirtyOil
Had I known about the Goose Box before grabbing the Andersen altimate, I would have been all over that Goose Box!!! No fifth wheel hitch to drag out of the box to use the full box, althought the Andersen is about 60lbs...that Goose box looks pretty sweet!! I pull goose necks for work and paly with the fifth wheel on days off, so hooking up safety chains is nothing. Adding safety chains to the Goose Box wouldn't kill the deal for me.
GUTS GLORY RAM
Supreme_Oppress
I'd check your local laws before believing Reese. Some simply state "all ball style hitches require safety chains". Whatever they do to dampen the movements that can damage the frame, the connection to the tow vehicle is still a standard ball hitch.
(some locations it affects the ability to double tow as the primary connection cannot be a ball hitch).
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
mdamerell
I've used the Reese Goosebox since fall of 2012. The only issue I have is I have to put air in the air bag every time I use it. The relieve valves on the air bags sometimes have a slow leak in them. Trailer rides just fine. Got caught on the edge of a tornado last year and it behaved better than some semi's I've driven.
Last time I talked to Lippert they talked about offering it as OEM.
According to Reese since it's an RV and built to some standard (can't remember the numbers) 5th wheel rules apply and chains are not required. Since I have spare hole in my "pin box wings" I was thinking about adding a set just to avoid any discussions with law enforcement.
My Goose Box is mounted in the bottom holes. When it as not, the ends of the "wings" on the pin box mounting brackets would get too close to my bed rails for comfort. In the bottom holes I have plenty of clearance.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
