TubaPete's avatar
TubaPete
Restricted propane Flow
I am having trouble with the flow from the right hand side propane tank in my fifth wheel. (This is when the left tank is empty.)Everything will work off of the right tank except the furnace. When the furnace comes on the system shuts down as if the tank were empty. I can shut down the furnace, wait for system pressure to build up and everything will work, except the furnace.
The system has a small red regulator on the right tank side and I know the tank pigtails have some type of leak restriction built in. So my question is what is the likely culprit, the pigtail of the little regulator?
Obviously I have no idea why the system has the little red extra regulator.
