mbrower's avatar
mbrower
Roof top AC mounting??
My signature Fifth wheel has two coleman Mach series AC units. I have no inside mounting frame (that I can find anyways) and was curious if anyone has removed these type of units that could shed some light on how they are mounted to the roof. I would like to replace the seals and would rather have some insight rather than trying to figure out on my own. Thanks!!
  • bpounds wrote:
    Mine clamps to the roof. Pull the inside A/C shroud and you'll probably see the fasteners going up from below. There is nothing on the top side involved in holding mine on.
    i Think I have what they call a race track type plenum where both AC units dump into the same duct. Either AC unit can supply the whole coach but when both are working I have much stronger air flow. I like the design but all I have on the inside are small round supply registers and 4 small rectangular return ducts no where close to where the AC units are. The mounting bolts have to be outside under the shrouds.
  • Mine clamps to the roof. Pull the inside A/C shroud and you'll probably see the fasteners going up from below. There is nothing on the top side involved in holding mine on.
  • Jerry B wrote:
    Mine is simply bolted to the roof. Take off your ac shroud and you will see four lag bolts near each corner. Piece of cake.
    Ditto with my Dometic Quite cool units
  • Allworth wrote:
    I would go to the Coleman website and see if I could find an installation PDF.
    Tried this first. All the installation PDFs I could find showed the mount using a interior metal mounting frame which mine did not have.
    Thanks!
    I think this may be how mine is mounted. Thanks!
  • When replacing the unit after installing the new seal, beware of overtightening the bolts/nuts, as this can crush the seal =too= much, causing leaks. Or so I've read on here about 'leventy-nine times... :-)
    Lyle
  • There are a number of UTube videos on this subject - might help.
    On my rig when you remove the interior shroud you see 1" wide square metal frame which runs along the perimeter of the square hole. There are 4 bolts that run up into the roof air conditioner. You remove those bolts and disconnect the wires ... once that's done you can lift the upper air conditioner.
  • Mine is simply bolted to the roof. Take off your ac shroud and you will see four lag bolts near each corner. Piece of cake.
  • I would go to the Coleman website and see if I could find an installation PDF.
