debili
Jun 09, 2021Explorer
Same problem as last summer AC leaking inside
Hi all Im back same problem as last yr. My AC in front Bedrm. is leaking inside. Both seals were replaced at the end of last summer.
I was on top of RV this am removed cover there is nothing blocking the drain holes if I am looking in correct place.
I called the guy that replaced them he told me of other rare thing the four bolts in four corners to tighten to hold unit tighter did that and again its leaking.
He insists it is the drain holes are clogged.
Does anyone have a diagram or drawing to show me where these stupid holes are? There is no tube or hose.
I did not remove front housing of the unit and do not believe that I need to? The cover yes the housing no please help.
2011 Jayco Eagle 351RTLS
