EgorKC
Aug 08, 2017Explorer
screws on gas spring stripped
Our outdoor kitchen door is held open by 2 60 lb. gas springs from the factory (2012 unit). When I opened it this weekend one of the 2 came off where it attaches to the door panel (the wood under the panel liner does not seem damp or crumbling due to wetness). I tried gluing a couple toothpicks into the holes, allowing to dry over night and reinstalling screws. They came out after 1st use. I will likely try that approach 1 more time using a better glue and wood however the chance of that working is slim. I can make a larger plate to rivet the bracket to and screw that in and have read other forums where that worked. Does anyone have other options besides a thru bolt which is unsightly.
Thanks for your insight.
Greg
Greg
