jonesjj42's avatar
jonesjj42
Sleep number
Bought a Sleep Number radius king that came with corner locks for the head of the bed, but nothing to join the foam walls at the foot. Currently have them joined with a couple of L-shaped corner locks sleep number finally sent me because they can't find out what part number is used for a rounded corner lock. Result is a mattress with a rounded top, squared off bottom and basically an expensive incorrect installation. Does anyone have a sleep number radius end mattress that is correct?
  • Same here, square at head and rounded at the foot. Biggest problem many times is the short RV plate form the matteress is on. Our sleep number is now in it's third 5er and on each I have pulled in the slide and replaced the OEM plywood and installed one wider and longer (as long as I could go without hitting anything).
  • edatlanta wrote:
    I have a Sleep Number Radius King as well and the head of my mattress is square with rounded foot corners. I assembled it 5 years ago so I don't remember all of the details, but unless they have changed something the rounded corners are at the foot only not the head. Assuming your bed support is set up that way.
    That's the way ours goes, square at head & radius at feet.
  • I have a Sleep Number Radius King as well and the head of my mattress is square with rounded foot corners. I assembled it 5 years ago so I don't remember all of the details, but unless they have changed something the rounded corners are at the foot only not the head. Assuming your bed support is set up that way.
