bapple's avatar
bapple
slide gasket coming loose
We have noticed that one of our slide gaskets inside is coming loose. What can we use to glue it back in.
Thanks
  • Thank you for your help. We ended up at an auto store and they recommended a glue. Here's hoping it works.
  • A picture would be helpful. So many different types of seals. Some clip on, others snap on, some have a self-adhesive strip and still others are simply glued. If you are positive you have a glued type of seal you can use 3M Supper 77 Adhesive Be very prudent using it...it sticks well and not easily removed if you tack in the wrong place.
