- silverthunderroExplorerThanks everyone for the info
- redsb3Explorer
pigman1 wrote:
Hydraulic fluid is hygroscopic. Means it absorbs water from the air. Some can absorb enough water that the steel parts in contact with it start to rust. Ergo, why you change it periodically.
Not all hydraulic fluids are hydroscopic. True petroleum based oils are not. Even transmission fluid is not hydroscopic. The water comes from head space in the reservoir and temperature changes which causes condensation to form on cooler surfaces. If you get a cap for your reservoir that prevents moisture from entering, you won't have a water problem. - pigman1ExplorerHydraulic fluid is hygroscopic. Means it absorbs water from the air. Some can absorb enough water that the steel parts in contact with it start to rust. Ergo, why you change it periodically.
- Me_AgainExplorer III
craig7h wrote:
Lippert recommends the fluid be changed ever 36 months. I was having some problems with the slides creeping out with weather change. I changed the fluid and problem was solved. The hard part was getting the fluid out of the reservoir, ended up using a turkey baster.
http://lci1.com/images/support/manuals/om-5th-wheel-hydraulic-slideout-landing-gear-pre-2008-web.pdf
If people would put left square bracket url right square bracket before a link and left square bracket /url right square bracket behind it, their links would be clickable!!!! Chris - rtateExplorer
Save the old fluid to bast your turkey thanksgiving. - craig7hNomad IILippert recommends the fluid be changed ever 36 months. I was having some problems with the slides creeping out with weather change. I changed the fluid and problem was solved. The hard part was getting the fluid out of the reservoir, ended up using a turkey baster.
http://lci1.com/images/support/manuals/om-5th-wheel-hydraulic-slideout-landing-gear-pre-2008-web.pdf - Me_AgainExplorer III
silverthunderroad05 wrote:
When should the fluid be changed and what is recommended?
Without leaks the fluid should last many years. It a closed system that is lightly used. ATF fluid is a good hydraulic fluid.
The red color is good for identifing that it is leaking.
Chris
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
