ed-myrna's avatar
ed-myrna
Slide out not fully extending at bottom
My 2013 Cougar 317RLS has the cable controlled slides. The dinning area slide does not seem go out all the way at the bottom. The cables seem to be adjusted as recommended but there is about 1" difference between the top and bottom of the slide. Anyone have similar problem? Is there a way to fix it?
  • Thanks, all of you. I thought I might be missing something, I do have the instructions of how to adjust the system but don't seem to be getting the result I'm looking for.
  • I have the same problem with my Vizion, also a Keystone product. There are instructions online as to how to adjust the cables. The slide also sags slightly when extended. The top starts moving before the bottom when extending. My problem is I can't figure out if I am to tighten the bottom (out) and loosen the opposing or losen the top and tighten the opposing.
    I suppose someday I will just take it in and have it done correctly.
  • YouTube. Find out how to do everything on YouTube. Once you figure out which adjuster does what it is not too difficult.
  • check and see if anything is wedged somewhere. my neighbor had the same issue and there was a dog toy that had rolled around while driving and got wedged when he tried to open it.
