grahampconradExplorerMay 10, 2015slow chargeCan i plug in a trickle charge to a 15 amp line say, three days before i go on a trip? Will that be all i need to charge the battery?
5 RepliesReplies sorted by NewestDave_H_MExplorer IIMay 11, 2015Personally, I think trickle chargers are out of style.I use a maintainer on my RV batt and have the batt switch off.I just do not see the need to have the whole system powered up all the time.2oldmanExplorer IIMay 10, 2015maybepianotunaNomad IIIMay 10, 2015Hi,Better to use the converter, particularly if it is a 3 stage unit.TodduptonExplorerMay 10, 2015Why don't you just plug in your 5th wheel and let the converter charge the battery?Dakota98ExplorerMay 10, 2015Depends,What is the current SOC of the battery as measured with a multimeter with NO load ?X-2 on the using the Converter, if its a 3-4 stage charging profile
