solar panel blowout
funpro
I have an 80 watt solar panel installed on top of my 5th wheel. It was originally a portable solar panel that was put permanently on top. The controller was left attached to the underside of the panel. It was connected to two 6 volt marine batteries in the 5th wheel. I have a kill switch so there was no power going into the trailer. Trailer was unused for about 5 months. Went to check it out and found that the cord from the solar panel to the batteries was fried at the fuse and in two separate pieces. Batteries were dead. Any suggestions on why this happened.
5 REPLIES 5
christopherglen
You *should have 3 fuses, one at each power source. The panel, the controller, and the batteries. Each fuse ~25% bigger then the expected max for charging, but not oversize for the wiring. The panel fuse should be at rated output + 25%, the other two fuses should be panel WATTAGE /10, +25%. As long as the fuses aren't to big for the wiring, that covers all charge controllers - mppt and shunt. Did I mention do not use fuses to large for the wires? Put the fuses as close as reasonable possible to the power sources.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
funpro
Thanks for the input. I am trying to attach a photo of the broken and burned fuse connection. The fuse is about 1 foot from the battery connection. The controller is up on the roof and about 5-6 feet from the batteries.
full_mosey
I believe you meant to say that the "cord between the controller and the batteries" was fried. This would have been caused by a short on the battery side wiring because it is unlikely that an 80W panel could fry the wiring.
When you rewire, place the controller as close as possible to the batteries.
HTH;
John
Vulcan_Rider
Something shorted out.
Wires.
Batteries.
A component in the controller...which drained the batteries.
BUT it would appear that the fuse was installed wrong or the wiring shorted out between the fuse and the batteries or the fuse was just simply too big. Did the fuse blow ??
Hard to say for sure without seeing a connection diagram and seeing the wiring.
2oldman
Where is the fuse?
