funpro's avatar
funpro
solar panel blowout
I have an 80 watt solar panel installed on top of my 5th wheel. It was originally a portable solar panel that was put permanently on top. The controller was left attached to the underside of the panel. It was connected to two 6 volt marine batteries in the 5th wheel. I have a kill switch so there was no power going into the trailer. Trailer was unused for about 5 months. Went to check it out and found that the cord from the solar panel to the batteries was fried at the fuse and in two separate pieces. Batteries were dead. Any suggestions on why this happened.
  • Please do not multiple post
    See other thread running.
    Admin
  • I would guess there was a short in the wiring from your battery to your charge controller. The short must have pulled more current than the wire could handle. What size wire and what size fuse was it?
