beelbill
Apr 17, 2015Explorer
That went as expected-Part Deux
After my first failure to get the 5th wheel backed into the site. I got a friend of mine to help guide me this time and I ignored my wife(after 25 years of marriage that part is getting easier). Put the 5th wheel in position with one try. Felt real proud. Then I went to unhitch it. I cranked the landing gear up to where I thought it should come free and I went to pull the handle but it would not release. So I cranked it up higher pulling the handle every little bit but nor release. I saw the back of the truck start to lift so I lowered it slowly pulling the handle every little bit. Still wouldn't release.
When the landing gear left the ground I figured I must not have gone high enough before. Maybe the truck was just lifting from the weight coming off of it. So I cranked it back up again pulling the handle every little bit. Still no release. Then the switch stopped working. I figured I had run the battery dead. So I hooked the power cord back up to the truck to charge it. Still now power. So I took the gas tank out of the 5th wheel and went to gas station to fill it up. Came back, hooked back up the quick release and went in to start the generator so I could have power to run the landing gear. Gas sprayed all over. I found out why it is called a quick release and not a quick connect. Could never get it to stop spraying gas.
Gave up on generator and searched inside fuse panel looking for blown fuse. No blown fuse. Traced power line for a short and found an inline fuse. Drove to auto store and got new fuse. Replaced the fuse and the landing gear worked again. Went back down and back up again. Stopped where I felt it had to come loose and got in the truck. Pulled forward slight amount, no release. Backed up slight amount and it released. Pulled out from under the 5th wheel and locked it up. I figure after I recover for a week or so, I will try to hook it up to water and electricity. Can't imagine anyone doing this for a weekend trip.
