May-27-2016 06:19 PM
May-30-2016 10:04 AM
May-29-2016 09:22 PM
May-29-2016 07:16 AM
May-29-2016 05:18 AM
I was thinking about adding air bags in the rear and front of the truck. Not so sure what I'm going to do now
May-29-2016 02:56 AM
May-28-2016 09:47 PM
May-28-2016 06:52 PM
May-28-2016 04:16 PM
garyp4951 wrote:
I will never have a tv that is not straight on viewing, unless the recliners are movable.
May-28-2016 01:24 PM
May-28-2016 01:00 PM
May-28-2016 10:04 AM
Me Again wrote:
Looking at the FPs I like the 321RL much better with straight on viewing of the TV. I just do not understand the apeal of rear entertanment floor plans. Chris
May-28-2016 09:58 AM
Greene728 wrote:IdaD wrote:mtofell1 wrote:
Hasn't it been well established that the only difference between a 2500 and 3500 is the rear suspension? In the case of the Ram in question the coils are a limiting factor but with a set of airbags isn't the truck the exact same machine as a 3500? Same brakes, frame, engine, gears, etc, etc.
There's a 500 lb difference in RAWR between the two, and that's the coils vs leafs. Everything else is the same. Put airbags or timbrens on the 2500 to address the slightly softer suspension and you've got the same or perhaps better capability than the stock 3500. The low payload rating is due to the class 2 GVWR limitation. This is real world truth.
The rv.net version is he needs a semi with a suitable payload sticker to pull a utility trailer. Why let facts get in the way of that?
All that being said, for that size trailer it may be worth stepping up to DRW.
Dear OP
I hope you can read between the lines in the above post and realize the sarcasm.
Here's some more truth.
http://news.pickuptrucks.com/2011/12/can-you-boost-your-payload-ratings.html
May-28-2016 08:30 AM
May-28-2016 08:19 AM
Calicajun wrote:
First thanks for all the comments. Wish I had made this post a year ago before buying the 2500 truck. At the time I thought a ¾ ton truck could pull most anything.
Only question now is which one of you wants to tell m wife she can't have the 5th wheel? ?? ??
Thanks again,
Craig
