crewstx's avatar
crewstx
Tire Balancing
I am changing to Goodyear G614 tires on 16 in rims for my 2010 Montana 34RL.
The dealer on has center holding wheel capability but can borrow the finger holding set. Treditt which manufacturers the wheel rim says they are meant to be center balanced only by use of finger balance method which picks up bolt holes.y Montana dealer says they do not balance their tires unless they get a reason such as large vibration.
I have had two tier places try to balance these tires and each time they get a balance at one place on the balancer and the rotate the tire about 90 degrees the next time it shows out of balance.
Is my dealer correct in that you do not need to balance fith wheel tires. and has anyone else had this experience?
