Shoe2728
Mar 10, 2015Explorer
Tire inflation
Got E rated tires installed, 80psi max, Tire guy said it would be better to run around 65-70 psi as tires heat up. Always thought I should run max cold rating 80psi. FW weight is around 9000 lbs hooke...
rhagfo wrote:
Me Again, looking at your chart, if I took the time could likely find in my Owners Manual.
You like me have the optional 265/75-16E tires, the rear axle load rating is based on the stock 245/75-16E at 3,042# ea. 6,084# rating, With the 265/75-165E's ea. tire is rated at 3,415# so you don't need 80 psi to carry the axle load.
We have done our work, those that choose to run 80 psi in their LT E tires all the time will be rewarded with a very nice bald patch down the center of their tires. :S
