โApr-12-2020 04:50 AM
โApr-12-2020 10:41 AM
โApr-12-2020 10:38 AM
jbemsc1 wrote:
Does anyone one know if a light truck tire is recommended instead of the tires that come from the factory. I have been told that I should consider a light truck tire.
โApr-12-2020 10:32 AM
โApr-12-2020 10:28 AM
BB_TX wrote:
I have used Michelin XPS Ribs LT tires on my 2007 5er almost since new. And they are great. Have never even had a low tire. And the ride is better than the original ST tires I replaced. But you do need to be aware of the weights. As mentioned above, the LTs I have are rated for 3,042 lbs. But that works great for me as my total weight is about 12,500 lbs of which about 2,500 is on the pin.
โApr-12-2020 10:27 AM
Cummins12V98 wrote:cummins2014 wrote:N-Trouble wrote:
Wont run anything but LTs. Bridgestone Duravis R250. I dont get caught up in all the capacity numbers like some of the propeller heads in here. Simply holding a good LT tire in one hand and a shitty ST in the other tells the story. No comparison...
Well sure you won't . Your toy hauler has a dry weight of 8755 Gross of 11,900, and a pin of 2035. Loaded to your max GVWR, and being conservative at 20% on the pin you are about 2380 per tire ???? Why not run LT's @ 3042 per tire.
There are some of us propeller heads running just a tad more then 2380 per tire. I am sure you don't get caught up in capacity numbers either at your weigh.
What are U talking ABOOT EH?????
I am "ONLY" 4,360# average per tire. More recently I have gained a few pounds and now running 4,495# per tire average.
โApr-12-2020 10:18 AM
FIRST thing what size and load range tires are you running and second thing what weight are on all 4 tires??????
So until you answer these questions all you are going to hear is "BLA BLA BLA".
This should be fun :B
No fun unless the OP gives enough info to receive a worthwhile answer.
Lot's of people "recommend" LT tires on RV's. Don't think anyone "OFFICIALLY" recommends LT tires on RV's???
โApr-12-2020 10:15 AM
โApr-12-2020 09:43 AM
โApr-12-2020 09:40 AM
โApr-12-2020 09:14 AM
โApr-12-2020 08:42 AM
โApr-12-2020 08:36 AM
โApr-12-2020 07:48 AM
โApr-12-2020 07:43 AM
โApr-12-2020 07:03 AM
