Feb-14-2019 01:17 PM
Feb-15-2019 09:44 AM
Feb-15-2019 09:43 AM
Feb-15-2019 07:43 AM
Feb-15-2019 06:53 AM
Feb-15-2019 05:53 AM
Feb-15-2019 05:20 AM
Feb-15-2019 05:03 AM
Feb-15-2019 04:50 AM
Feb-15-2019 04:35 AM
Feb-15-2019 04:22 AM
RonLB wrote:
I suspect this has been asked and answered...
The 5th wheel trailer we are looking to buy has a gross weight of just under 16,000 pounds. We are planning on trips out west going through mountains. Am I naïve to think that a vehicle with a max towing capacity of 17,000 pounds is going to be adequate? We are buying both a trailer and a truck. One of the worst things that could happen would be to realize the truck we purchased does not have the horsepower or just barely has enough horsepower. Are we better off getting as much horsepower as we can afford? Comments please. Thanks in advance.
Feb-15-2019 03:53 AM
Feb-15-2019 12:27 AM
Feb-14-2019 08:08 PM
JIMNLIN wrote:RonLB wrote:
I am beginning to appreciate that we should be looking at a 1 ton truck. Why the dually? The trailers we are looking at are Keystone Avalanche's...39', 40' or 41'.
A one ton SRW has 7000-7230 rawr and is good for around 3500-3700 lbs in the ..on the rear axle/2 tires. A stripped down std cab 2wd long bed with the right numbers may work
A one ton DRW has much larger 9750-9900 rawr and good for around 6500 lbs in the bed ....over the rear axle/4 tires.
Above weights are a estimate but ponts you in the direction. Of course a new gen diesel in any 3/4 or one ton truck won't have any problems pulling a 16k lb trailer.
A 16k lb trailer can have 3200-3800 lb pin weight depending on floorplans and how its loaded. Now add a heavy hitch .....people....and other gear...maybe 4000 lbs. Like above numbers are a estimate to show how numbers can work.
ScottG wrote:
While lesser trucks may be spec'd to tow it, my experience tells me a rig of that size is solidly into 1t dually diesel territory.
Feb-14-2019 06:45 PM
