BlackSS's avatar
BlackSS
Towing this with 3/4 ton
Looking for thoughts on how this would behave:
2013 F250 diesel crew cab (short bed 4x4)
pull rite slider
From Ford Spec sheet:
GVWR 10,000#
Max payload: 3240#
Max 5th wheel trailer weight 15,900
Looking at buying a 2005 Jayco Talon 36Z
The specs I have found from a Jayco spec sheet:
Dry weight: 10,500#
Dry pin weight: 2,495#
Gross weight 14,900#
I will verify these numbers with Jayco when I get VIN # from seller.
By the book this is "legal" combo. Pin weight may get high if fully loaded, but most of the weight would likely be behind the axles in the garage and not add much in terms of pin weight. I would think that with 2000# of gear in the trailer I would be approaching the limits of pin weight considering people and gear in the truck.
Thoughts from people that have done something similar?
